shamanblue Posted September 13, 2015 Author Share Posted September 13, 2015 negative only connected between panel and power rios. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430463 Share on other sites More sharing options...
james.wilson Posted September 13, 2015 Share Posted September 13, 2015 Neg common isn't needed for rs485. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430466 Share on other sites More sharing options...
Nova-Security Posted September 13, 2015 Share Posted September 13, 2015 Neg common isn't needed for rs485. It is on Galaxys www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430468 Share on other sites More sharing options...
james.wilson Posted September 13, 2015 Share Posted September 13, 2015 It isn't mate. Try it I only commoned em when using split outputs securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430472 Share on other sites More sharing options...
shamanblue Posted September 13, 2015 Author Share Posted September 13, 2015 All modules are at 100% in Diagnostics except Keypad 19 which is at 0%. I have seen the ethernet comm port 4 and the Keypad 15 both drop to 96% occasionally but the ethernet card is in the panel connected using the engineer lead that plugs on to the four pins Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430476 Share on other sites More sharing options...
Nova-Security Posted September 13, 2015 Share Posted September 13, 2015 All modules are at 100% in Diagnostics except Keypad 19 which is at 0%. I have seen the ethernet comm port 4 and the Keypad 15 both drop to 96% occasionally but the ethernet card is in the panel connected using the engineer lead that plugs on to the four pins And then you data line out is taken from the ethernet module ? It isn't mate. Try it I only commoned em when using split outputs Must be, as it doesnt work on remote buildings unless common the negs, may be as they are not on the same supply. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430477 Share on other sites More sharing options...
al-yeti Posted September 13, 2015 Share Posted September 13, 2015 Honeywell documents the ground going through, so that's all coblers? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430480 Share on other sites More sharing options...
james.wilson Posted September 13, 2015 Share Posted September 13, 2015 Shouldn't make any odds 485 doesn't need a voltage reference. It's common advice due to output switching really not needed. It's not done on cameras across phases for instance. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430481 Share on other sites More sharing options...
al-yeti Posted September 13, 2015 Share Posted September 13, 2015 Is it an adt firmware Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430482 Share on other sites More sharing options...
james.wilson Posted September 13, 2015 Share Posted September 13, 2015 Honeywell documents the ground going through, so that's all coblers?Look at the 485 protocol it will show it's needed. Plus as above you link negs on cameras. Trust me 485 does not need a common to work. Other stuff does but not the dataIs it an adt firmwareFirmware is irrelevant Don't get me wrong its good advice to prevent switching issues, but isn't needed for just data I wouldn't as a rule common negs unless switching outputs across expanders. Electrical isolation is preferable imo securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39094-galaxy-dimension-48/page/2/#findComment-430484 Share on other sites More sharing options...
