Fastbluecar Posted August 4, 2015 Author Share Posted August 4, 2015 Could someone point me to a source of this chip? And it's part number? FYI This morning the panel suddenly sprang into life after having refused to accept any commands and showing nothing on the display. It had returned to factory settings. I've reprogrammed it, and it appears to be working fine. Looks like it just wanted a couple of days off!! I think I willtry a new NVM, and ultimately a new panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426194 Share on other sites More sharing options...
al-yeti Posted August 4, 2015 Share Posted August 4, 2015 Waste of time , move with the times , it's been in long enough get something up to date , keypad will fail soon enough to Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426195 Share on other sites More sharing options...
datadiffusion Posted August 4, 2015 Share Posted August 4, 2015 I would add that it sounds very much to me like you need a new battery, too. Even if it was OK, if it has been drained pancake flat, it may never recover. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426204 Share on other sites More sharing options...
charlie6 Posted August 4, 2015 Share Posted August 4, 2015 ".... I think I willtry a new NVM,.." Don't see the point if you've got it up and running, and personally I wouldn't waste my time looking for a replacement chip. Enjoy the panel as is for now, but give serious consideration to Al-yeti's comments viz; new panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426206 Share on other sites More sharing options...
datadiffusion Posted August 4, 2015 Share Posted August 4, 2015 As I have said before, this is a common and known fault with this panel. It will only be hours / days / weeks before it fails again either in the middle of the night or during a power fail, especially if the battery is knackered. It is likely only the live power on the panel that is currently sustaining the NVM, or as it current is VVM, Very Volatile Memory. At the very minimum a new battery and 24C16/M24C16-WBN6P DIP-8 Serial I²C Bus EEPROM is required. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426207 Share on other sites More sharing options...
charlie6 Posted August 6, 2015 Share Posted August 6, 2015 Datafussion, Is this a cradled eeprom on this panel or does he need to get the soldering iron out ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426529 Share on other sites More sharing options...
norman Posted August 6, 2015 Share Posted August 6, 2015 Cradled Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426530 Share on other sites More sharing options...
charlie6 Posted August 8, 2015 Share Posted August 8, 2015 Thanks Norman, Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-426606 Share on other sites More sharing options...
Fastbluecar Posted December 9, 2015 Author Share Posted December 9, 2015 Finally got round to trying a new NVM, however when got the panel apart, it is fitted with a NMC9314BN. Datadiffusion says I needed a M24C16. Are these the same chip? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-436503 Share on other sites More sharing options...
datadiffusion Posted December 9, 2015 Share Posted December 9, 2015 Should be fine - at your own risk. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38874-scantronic-not-responding-after-battery-change/page/3/#findComment-436505 Share on other sites More sharing options...
