CASSSS Posted June 1, 2015 Share Posted June 1, 2015 i removed 3 pirs to redecorate and after the alarms went off i put in the code. i also changed the bell box as the bell was muffled. when i went to set the system zones 2-7 lights come on and it beeps 8 times. it wont let me set. i also notice 3 of the pirs does show the red led when i walk past them. i have 8 zones 1 of which is a panic. please help urgent Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/ Share on other sites More sharing options...
datadiffusion Posted June 1, 2015 Share Posted June 1, 2015 Hi, welcome to TSI. The best way to get urgent help is to call a local professional - whereabouts in the UK are you? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419497 Share on other sites More sharing options...
CASSSS Posted June 1, 2015 Author Share Posted June 1, 2015 I was just after some advice on here on how to do it if anyone could help me Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419508 Share on other sites More sharing options...
morph Posted June 1, 2015 Share Posted June 1, 2015 You may have faults on zones 2 to 7 so that would be the best place to look for a problem. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419516 Share on other sites More sharing options...
Hillbilly Posted June 1, 2015 Share Posted June 1, 2015 I would check the panel fuses first. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419522 Share on other sites More sharing options...
CASSSS Posted June 1, 2015 Author Share Posted June 1, 2015 Yes but if it's fuses then the lights wouldn't work on some pirs and not others Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419541 Share on other sites More sharing options...
Adi Posted June 1, 2015 Share Posted June 1, 2015 All depends where they took the power from? I really can't be ar**** with it anymore. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419542 Share on other sites More sharing options...
CASSSS Posted June 1, 2015 Author Share Posted June 1, 2015 All power are wire twisted to +v Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419644 Share on other sites More sharing options...
CASSSS Posted June 2, 2015 Author Share Posted June 2, 2015 How do I reset to factory settings I only have user code Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419646 Share on other sites More sharing options...
al-yeti Posted June 2, 2015 Share Posted June 2, 2015 We can't give that info out But it seems when you disconnected your sensors you havnt connected them back correctly As said "above" you have problems with zones 2-7 possibly If you didn't mess with wiring in control panel that should be ok But zone 1 is a door contact yes? So won't help you to wire the pirs Each pir will have a negative and positive sometimes it's red and black sometimes it isn't , but if your saying in the panel all of them are connected to +'ve then you need to check what you did in your pits again Why don't you load some pictures of each pir here ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38572-texecom-veritas-r8-plus-wont-set/#findComment-419647 Share on other sites More sharing options...
