skywalker Posted May 30, 2015 Share Posted May 30, 2015 removed a samsund PTZ during an upgrade a while ago and finally got around to putting it up at home the other day, but i can't get into the setup menu of it! i'm sure i got into it in the past when i was testing it on the bench but just can't now!its running pelco P, 4800B, ADD2. i've tried preset 95, 64, and 126 but having no joy. any ideas? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 30, 2015 Share Posted May 30, 2015 So you can make it move? But not bring up menu??? Quote Link to comment Share on other sites More sharing options...
skywalker Posted May 30, 2015 Author Share Posted May 30, 2015 yep, i can control it and set and call presets no problem, just can't get into the damn menu Quote Link to comment Share on other sites More sharing options...
whistle Posted May 30, 2015 Share Posted May 30, 2015 All the samsungs we have fitted have been preset 95. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 30, 2015 Share Posted May 30, 2015 Better go through all the presets Quote Link to comment Share on other sites More sharing options...
Amps Posted May 30, 2015 Share Posted May 30, 2015 You set up as a Sole Trader yet mate? Quote Link to comment Share on other sites More sharing options...
breff Posted May 31, 2015 Share Posted May 31, 2015 Most pelco I've used you have to set preset 95, not call it. 1 Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
skywalker Posted May 31, 2015 Author Share Posted May 31, 2015 Most pelco I've used you have to set preset 95, not call it. BINGO! i was afraid to try that incase i 'overwrote' the menu command as most of the other PTZs i've used need 95 to be called. thanks! Quote Link to comment Share on other sites More sharing options...
breff Posted May 31, 2015 Share Posted May 31, 2015 No probs Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
