Elevator Cctv Camera System
Hi all
I am for a bit off advice I have got a site with 6 lifts and the customers wants to install camera in all the lifts. I am going to get prices from the list ft company to do the work but I am looking at using a wirless lift camera system has anyone used one before and are the ok or have you had problems with them or would you get them to cable the lift instead ?
Defenatly go with the wired option, Far to may variables that will cause problems with a wireless soloution. Also you will need to get power to the camera so there will have to be some cabling for that anyway.
  • 3 weeks later...
We worked with the lift co. who installed a Cat 5 loom from car to cabinet(although it was for IP cam).  Even if using spare pairs we'd still go through lift co. to do it.
What sort of price price does it cost to get the lift company to run cat 5 cable in the lift ?
Don't forget even if there is only a single spare pair, even if not twsited, you can get 2-wire IP transmitters such as from Solwise
Hi have you got a part number I have looked on solwise website and can't find 2 wire transmitter
http://www.solwise.co.uk/net-powerline-homeplug-tp.html
It says twisted pair but they admit themselves it works perfectly on crappy CCA doorbell cable, so should be fine on short runs and cant imagine a lift company using rubbish cables in the loom.
