SL Compact
I wonder whether anyone has a manual for a SL Compact alarm system, which was installed in my house when I moved in?
I am unable to find it on the Net, as I don't know what SL stands for.
Help!
Thanks.
  • Replies 25
  • Views 33.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Did you get a manual for the SL compact? I need to get hold of one to try to reset an alarm as we’ve moved into a new house and haven’t a clue of the code!
  • You think after 16years he has hopefully binned the alarm altogether.....   Not sure if you will get a reply
  • If you dont know the code then the user manual wont be much help, take a look at the bell box to see if thee is an installers name on it, give them a call and they will default the code for you for a
Just emailed you some manuals, let me know if there the right ones.
SL stands for security lighting according to the manual , its a basic ADE Optima XM type panel with non programmable zones.
  • 2 months later...
Same as ceemgee. Is there a copy of the SL Compact alarm system manual. I have recently moved flat and my security number has been left as was by the previous owner.
Thanks
  • 2 months later...
HELLO DID YOU GET A MANUAL FOR YOUR SL COMPACT ALARM, PLEASE CAN YOU HELP ME I NEED TO RESET THE PANEL AFTER A TAMPER I CUT THHROUGH A WIRE WHEN I WAS DOING SOME FLOORING I RE CONNECTED THE CABLE AND THERE IS A TAMPER ON THE PANEL AND I CANT USE IT I KNOW THE SECURITY CODE AS IT IS MY HOUSE PLEASE CAN YOU CALL ME ON [EDITED] OR E MAIL ME : [EDITED] THANK
AKAY
Edited by datadiffusion
Personal details removed as I was reading this anyway
This one seems suspicious!!!
If your home WAS your own home - there would be no need to say this?
Should the risk be taken?
Only a mobile and a hotmail address..
Red Fox | Hosting
Affordable and Reliable UK Based Web Hosting
The cable you cut must have been to a powered detector, so you have blown the control panels 1A 20mm fast blow fuse, this is why the panel wont reset and still shows a tamper fault.
Youll need to replace the AUX fuse to get the panel working again, or call an engineer to get the system serviced (He`ll sort out the problem while servicing the system) and advise you of any other causes for concern, such as a dead battery. etc etc.
  • 1 year later...
Hi,
I have an SL Compact in my house that was already installed. I have the user pin but not the engineer code. I think the panel is based around the Optima or Acenta based on this forum. Whilst I have manuals for these I dont have one for the SL.
I have the manual for the Accenta range, and have attached a page of it here. If the SL Compact is just rebranded Accenta then I reckon I can just follow the procedure in this manual? But would still be good to get a clear cut answer and manual!
It would be a great help if you could let me have a link or copy of the instaltion manual for the SL Compact so I can reset the NVR and reconfigure the panel.
Thanks,
Nev/.
Edited by Nev
Why would you want to reset the nvr? if you know the user pin you can change the code, I cant think what else you would want to program?
Pete
Pete,
I want to reprogram the set programs to chose the PIRs in use. As far as I am aware this requires an engineer code, as I dont have this I was going to reset the NVR and basically set the whole thing up properly from scratch. There are a few othert abnomilies that the installer set, such as a zone 1 that has no sensors connected etc. Generally looks like a cowboy fitted the alarm or a DIYer.
If your saying that I can reset the engineer code with my user code then please tell me how as I have no manual for the panel.
Any help appreciated,
Nev
Edited by Nev
This topic is now closed to further replies.
