Replacement Panel And Keypad For Jsb Regent
Percha
Hi,
First of all hello!
I have a regent alarm panel and scantronic 9427. I want to replace panel and keypad. I have 5 pir's two door contacts, also two door contacts in garage and another key pad in the garage.
What panel and keypads do you suggest? I was think accenta g4 metal case one?
Can anyone suggest a good panel and keypad that is reliable and I could diy fit? Also I am thinking about the dialler option which I can see if you add the informa will do on the accenta.
Accenta would do then, with LCD keypad, better to have new battery
http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=864
Squeeze another £20-30 and get a dialler to
Panics are cheap
http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&cPath=36_46&products_id=2542
