chris77 Posted August 26, 2014 Share Posted August 26, 2014 Could someone help me here, I fitted a G2 panel 2-3 years back it has 12 zones expandable to 20 i belive. I would like to add an outbuilding to the system only acouple sensors its like max 20 m away from the house, is the C079-2 RF Portal the correct one. Can it be remote wired to the main panel ie I would like to place it at the end of the house nearest the out building to keep distance short. Also when adding a rf portal does this add aditional zones to the system or would I have to use one of the existing 12 zones ? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted August 26, 2014 Share Posted August 26, 2014 Yes, C079-2 is the best portal for the G2. The portal connects to the RS485 bus as per the keypad, so you can mount remotely from the panel. You can still have 12 wired zones and 8 wireless. Quote Link to comment Share on other sites More sharing options...
Lwillis Posted August 26, 2014 Share Posted August 26, 2014 The portal just uses up one of the zones so you can have up to 20 zones in any mixture Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 26, 2014 Share Posted August 26, 2014 Just be sure to address it , 4 or 5 on the g2 , or it won't see it Quote Link to comment Share on other sites More sharing options...
chris77 Posted August 27, 2014 Author Share Posted August 27, 2014 Can anyone confirm it will work fine on version 1.5 panel firmware. Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted August 27, 2014 Share Posted August 27, 2014 Yes. 1.5X is fairly recent. Quote Link to comment Share on other sites More sharing options...
