Help: Agility 3 Follow Me Not Texting
I had Risco Agility 3 with IP and GSM modules installed 2 days ago with Asda pay as you go card. The installer set up the Follow Me, I've added my phone numbers and from user menu sent test message. Received test message. But it seems that there is no message is actually sent during defined events, ie alarm. I even went to engineer menu and added event to send message for setting an alarm and still no luck. Anyone have any ideas? If someone can ping me an installer guide for agility 3 that might be helpful as I've used standard agility manual.
Other question does anyone know how to set check balance using Asda sim? From website it should be text BAL to 2732, but setting it in panel and executing from user menu dont get me any results.
Installer manuals are not available to public areas, Suggest contact the installer to test and commission correctly,
as for pay as you go sim... if the sim is registered with you can you check online
Agreed, report it to your installer. also pay as you go is not best for obvious reasons.
All these instructions are in the installation manual.
The installer probably has not selected to send the cloud and FM channels at the same time and or changed the events for the users (very unlikely its the latter).
If you log into your cloud online, you can set up the email address for your users, this doesnt appear to affect your FM set on the panel and will give you email notification, it will not give sms notifcations from the cloud itself.
This way in the short term you will get an email for the event, the app should if logged in also get the event directly.
@secureiam thanks for the tip, I'll have a look into settings. Would you be able to tell where is it exactly in menu at least it will save me the time for going through menus?
Unfortunatley you need to ask your installer to resolve this for you, its their responsability to set this up correctly.
Tweaking a system and having no knowledge of that system is a very dangerous thing, you could inadvertantly make things much worse.
Your fortunate that if the engineer refuses to put it right you could get someone else in to ressolve this for you at a cost as you have access to the engineers code.
Totally agree we install these all the time, but it`s the responsibilty of the installer to check over, small but powerful panel, you could easily alter something else in the program, get your installer back or ask Risco for another installer details in your home area, but as mentioned be prepared for call out fee, or try their technical line
If you youre still having problems you can pm me and see what we can sort out.
may be able to access remotley via cloud with cpid and the cloud password do not publish these in public.
  • 5 years later...
Hello guys,
I have a Risco Agility 3 with IP and GSM - both comms working fine.
I have defined two Follow Me (FM), 1 = Me via SMS and 2 = The Wife via SMS also.
I as FM1 get all SMS for events defined no probs.
However, FM2 (i.e. The wifes phone) does not get anything - her phone is defined correctly - FM test successful (she gets a text) and she can set/unset via sms no probs.
Is this by design perhaps, that the system tries the FM numbers in order and if FM1 IS successful, i.e. a SMS was sent ok to FM1 THEN IT IGNORES ALL OTHER DEFINED FMs?
If so then it's a bit silly, as we would both like to get SMS for all events defined.
Any thought and ideas will be appreciated.
