Hello Everyone, Any Chance Of Some Help?
  • Replies 40
  • Views 15.5k
  • GalaxyGuy
    GalaxyGuy
    Okay, since the documentation isn't clear on this,  here's my test result from an FX20 panel when adding a RIO and C079 RF Portal.   First, you need to set the RIO address selector to 2, the
22 hours ago, al-yeti said:
What model rf portal is it ? Exactly you got picture ?
I've got A073-00-01, still got the same problem.  Don't know what else I can try, not much to configure really.  The board joust won't TX anything.
I'm thinking of buying another board to see if its faulty.  Is the C079 the same board in an external enclosure?  Can I just remove it from the external panel and put it in the main FX020 panel?
It's the correct board and it will not transmit until you've registered. Which detector type are you registering ?  Does it register with V2 ?
No v2 didn't work either, well the PIR (IR8M) didn't.  I haven't tried the fob (TCC800M) as its a little more fiddly with swap over.  Obviously I was in the correct menu for each device.
I didn't try "Russia" jumper, just the protocol jumper.  I also tried alpha to v2 and via versa just in case reading the switching wrong, but I didn't get any RX on the portal in these modes as expected.
alpha > alpha - RX flashes rapidly 3 times, no TX flashes..
v2 > v2 - No RX/TX
alpha > v2 - No RX/TX - as expected.
v2 > alpha - No RX/TX - as expected.
Don't know if it makes a difference but the RF version is v3.00 and the FX020 is v3.37.  I don't have any software or firmware update them anyway.
v2 > v2 - No RX/TX
Leave the portal at alpha and V2. Jumper 1 closed. Ensure that you power cycle the portal.
What is menu 51.60 showing as the portal address ?
Are you saying that when you press the * learn on the zone and set the IR8M to V2 and then add the battery, that the serial number doesn't populate ?  Remember that the newer detectors have two tamper switches, so if pressing the front tamper with the lid off, then you need to have the sensor in its back wall plate to close the other tamper as they're fitted in series.
On 14/06/2017 at 0:10 AM, Dklemm said:
Also the maximum wireless zones is 20 on the FLEX020 so the wireless must override be able to override the wired zone with its virtual address.
No, that's not correct. The FX20 only supports one virtual RIO, so 8 wireless zones.  If you add the portal on its own, the virtual RIO will be added at the next available address: 102.  So that's 100 and 101 for the on-board and 102 for the wireless.
Giving zones:
1001:1004 (Onboard terminals)
1011:1018 (Onboard terminals)
1021:1028 (Wireless)
What I needed to check is that when you add the external RIO at address 2, then add the RF portal and disable the virtual RIO at menu 51.60, do the remote controls still work.
Yes, I can't get the address to populate when trying the learn the devices.  I'll try the 2nd tamper switch tonight, I'm not 100% confident because I don't get from RX flashes from PIR but I'll try anything.  I'll also check the portal address.
I don't want to disagree with you because I can see you have years experience and really appreciate yoru assistance but this is the info from the v3 Installer Manual. Also when starting the RF learning process the keypad asks be to select a zone, it allows me to select from all 20 - I've tried selected from all 3 of the ranges you mention above.
Feature or peripheral
     Flex 20
    Flex 50
    Flex 100
RS485 Lines
1
1
1
Zones (on board)
12
12
12
Zones (maximum)
20
52
100
Zones (Wireless)
20
52
100
Many Thanks for the help!
Daniel
I was using the range comparison chart, so the documents seem to conflict.
http://www.security.honeywell.com/uk/documents/HSC-Flex-01-EN(0711)PC-C.pdf
The older G2 series used to allow for mapping wireless across all zones, but my understanding was that the Dimension and Flex implementations were different. I last checked that with older firmware, but haven't tried again on the most recent.
First, you need to set the RIO address selector to 2, then connect and configure onto the Flex bus with menu 72.  The zones are 1021 to 1028.
Then, add the C079 to the bus and address it using menu 72.  The address dial doesn't matter much here unless you have more than one portal to attach.  My test was set to address 0.
The C079 will try to configure its virtual RIO to addess 102, but cannot, as it's already used. It cannot shift up one as the FX20 only allows 20 zones and the onboard cannot be disabled. So, the virtual RIO sits dormant.
The bit that surprised me now is that the RF zones can now be mapped over the existing 20 zones anywhere, so you now have 20 flexible hard wired (8 outside the panel if you so wish) zones which can be converted into wireless.
If you add the RF Portal first, then it will snatch the RIO address 102 (even when you disable in menu 51.60) and the hard wired RIO will not configure onto the bus.
I hope that this clears up the operation - it's helped me to understand why I had to wrestle with this previously.
This panel was version 3.37 for the record.
GG.
I finally managed to get the PIR and Fob to correct using v2.  I think it was the 2nd tamper switch on the PIR and I hadn't tried the v2 on the fob .  I don't know why it didn't connect on the alpha protocol.
I have remove the RIO anyway, to avoid that confusing matters but will add that back in but after cold start in the order you recommend.  Although for info I think you can change the RF Address using Menu RF Address [51.60.1], according to the documentation.
GalaxyGuy many thanks for the help!
Regards,
Daniel
