Spider68 Posted October 29, 2013 Share Posted October 29, 2013 I have a Premier 24 that popped up a Battery Fault error after a recent power outage. On checking the battery I saw that the install date says it is 7 years old and it was not holding charge. So I replaced with an identical 7Ah unit which was charged up to 12.88V when I fitted it. But I cannot get the Battery Fault error to clear. I have tried switching the battery test config parameter from Timed->Disabled and back again but it doesn't seem to want to reset the battery fault state. Is there some other clear/reset procedure or could there be something else wrong with the system? Link to comment Share on other sites More sharing options...
Serg Posted October 29, 2013 Share Posted October 29, 2013 That is common issue on old Texecom panels, you need to power down and up the panel. Dont forget to set time and date after. Link to comment Share on other sites More sharing options...
Spider68 Posted October 29, 2013 Author Share Posted October 29, 2013 I did disconnect the PSU power to the board, but while the new battery was connected. You're saying that I should disconnect the battery and then disconnect the PSU power; and what order should I reconnect them? The Fine Manual is not very clear on the matter. Will it only be the date+time that is affected, I don't want to have to reprogram all the zone settings. Link to comment Share on other sites More sharing options...
matthew.brough Posted October 29, 2013 Share Posted October 29, 2013 That's right. Complete power down. All settings will be stored in the nvm. I'd power back up battery first. www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 29, 2013 Share Posted October 29, 2013 If that doesn't work it's the "Monitor Hardware shuffle". Link to comment Share on other sites More sharing options...
MrHappy Posted October 29, 2013 Share Posted October 29, 2013 with the battery fitted, does the system still work if the mains is turned off ? Mr Veritas God Link to comment Share on other sites More sharing options...
Spider68 Posted October 29, 2013 Author Share Posted October 29, 2013 All sorted. I disconnected the PSU power, then disconnected the battery (outside alarm sounds), reconnect battery (but no power indication), reconnect PSU power (all lights up) and I'm back in business. Thanks for all the help & advice. Link to comment Share on other sites More sharing options...
Ronnie Posted October 29, 2013 Share Posted October 29, 2013 We had a mains expander today flagging a blown fuse - only way to clear was to power cycle the expander.. Not ideal.. Link to comment Share on other sites More sharing options...
sjsturner Posted October 29, 2013 Share Posted October 29, 2013 That's right. Complete power down. All settings will be stored in the nvm. I'd power back up battery first. Id power mains first, always done it this way, some do say batt first in the manuals but i see mains as a softer start Link to comment Share on other sites More sharing options...
matthew.brough Posted October 29, 2013 Share Posted October 29, 2013 I didn't say I followed the manufacturers advice. Always wondered the obsession with battery first was. www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
