Galaxy Rf Portal
hi all.
wanting some pre install info. im installing a RF portal on to a GD 96 next week along with 3 honeywell piezo shocks.
I installed the main system 3 years ago but ive not yet used the wireless side of a galaxy before and would like some info on setting it up and things to look out for?
any info would be great. thanks Dan.
  • Replies 34
  • Views 26.1k
never used a portal on a g3.
But if its the same as the g2, you will need to get the serial number into the circuit you are using.
It's easy enough on a GD. Each RF portal is seen as RIO's and you can tell it how many rio addresses you want to take up.
It's a case of putting the panel into learn and tampering the device and all is well. Program everything else as a normal zone.
sounds easy enough. am i right in thinking its the RF rio's that you needed to connect a keypad to for setting up? :huh:
I remember on the radio Río you adressed it and enabled upto 4 rios. That was done via a keypad connected to the rio.
how is it done an the dimension. Plus at what firmware did it supports portals?
Yes, RF portal is done via the keypads.
6.5
6.5
That's confusing Matt!
The old RF RIO (C076) is seen by the systems as a RIO and is programmed by connecting a keypad locally to its programming header.
There are two RF portal models:
C077 Used on G2 series only and programmed in panel menus.
C079  Used on G2 or Dimension panels and programmed in panel menus.
C079-2 (new rev of C079)
Sorry it is. I meant a keypad on the system not a keypad plugged onto the portal.
hi all.
am i right in thinking i just wire it like a rio and then rescan system to find it? do you address it the same way with the pot or is it done another way?
thanks for all the replys.
hi all.
Yes, just wire it as a standard rio and when you exit engineers it will say x modules added. Rf portal can take up to 3 rio addresses depending how you set it up in the programming.
