Security Of Anti-Codes
Hence the rhetorical question.
Technically it's not encryption either. So, on a marketing and technical level, it's pretty bad.
Where's the line? "This alarm uses rolling code" and the rolling code is 1,2,3,4. Is that dodgy?
Indeed it does. All return anticode 18003
So if I am allowed chosen plaintext (i.e. I can call up the ARC and tell them whatever quote code I chose, and get a response), then it wouldn't require many pairs to get the keys. I don't know how possible this would be, as I think they would have to see an alarm activation, which means I would need a real quote/code pair.
If it's only known plaintext (i.e. I am using valid quote codes generated by the alarm), it would be quite a lot more pairs required. Still a tiny number compared to the security a 2048-bit key affords.
All of this would have been caught by an undergraduate doing a cryptography coursework "Is this homebrewed MAC secure?".
It wouldn't have been hard to make this secure at all. Actually, I think it would be less effort just using something ready made.
Edited by cybergibbons
http://cybergibbons.com/
How do I change that though? I've looked at a good few systems, enough that I can form an opinion of where they lie in terms of security. I've posted information on why I think the bad products are bad, some of which has been in quite a lot of depth. I can go into more depth, but as many have said, it would be beyond them.
I can argue that installers aren't in possession of all the facts - there are alarm systems that fall far short of the marketing.
The problem is that, and it is entirely your call, you only release some information whilst alluding to other products (unnamed) either having problems or inferring that they do.
This is very misleading to the public in general and to those amongst us who are quick to castigate a product (or company) but then do a 360 degree turn based on something they read on the web without being able to validate the new 'facts'.
But is it illegal? No.
Is it factually incorrect? i'd say no because no specifics mentioned.
In effect, no different to the bull put out by any other company or business.
You can't choose the code you quote to the arc, the remote reset unit decides that but most seasoned end users are clued up on the things to say to get a remote reset so you could generate some alarms, call the arc and get the resets for 'valid' reasons and you would have enough code and anticodes to do your maths.
I don't recall any point where I haven't given enough evidence to back up a claim about a specific product. If I haven't named the product, it is because the manufacturer has made it clear they would be interested in legal action, so I need to be careful.
The system that I didn't name that I don't think is good, I provided a document describing a similar system, and asked you to make your own conclusions. Open up a Scantronic wireless panel, look at that document, compare the radio modules, make your own judgement.
I don't know. I'd question the use of the word "encryption" under trading standards.
If your signalling system claimed it was encrypted and it turned out to be as weak as this, would that not be of concern?
Your constant play on words, inferences, claims suggesting you are the 'good guy' etc etc are misleading. The easily led fall for it, not i.
I'm out!!
I'm out!!
One of the big reasons I am here is to make sure anything I infer isn't false.
One of my many arguments for standardised protocols.  Why reinvent the wheel?  Especially when you make a round wheel square in the process.....
