Security Of Anti-Codes
One of my many arguments for standardised protocols.  Why reinvent the wheel?  Especially when you make a round wheel square in the process.....
Totally agree. I know webway use a few in their stuff rather than recreate something that already existed.
  • Replies 149
  • Views 35k
  • matthew.brough
    matthew.brough
    I've no idea what your on about. Select, insert and update are all strange words to me. Best pay technistore zillions to do it for me.
  • AdrianMealing
    AdrianMealing
    We like trouble at BSIA, I and others like a bit of disruption, make for interesting meetings, and gets things done, the old ways have to change, and so do the people involved the EU is going to stop
  • cybergibbons
    cybergibbons
    So I wonder what drove the standard to require that and where the 5-digit Technistore code fits in to this? There must have been some reason behind it being 5-digit - it's rarely seen as a code length
It is almost always without exception a bad idea to "roll your own" encryption:
http://security.stackexchange.com/questions/18197/why-shouldnt-we-roll-our-own
It's also a really bad idea to keep encryption schemes secret - the security should lie in the key, not the algorithm. If you keep it secret, the most clever person to look at it is going to be you. Make it public, and there is almost always someone more clever than you to take a look.
I partly understand why Technistore is like this - it was implemented for embedded systems 25 years ago. Even with that in mind, it's got issues.
http://cybergibbons.com/
but again technistore is just a reset algo. There are easy ways to reset a system than to hack it. It was originally a separate device that wired into the panel. It was then later added to panels as a built in function. Most panels don't even have a seed, ie castle, aritech etc. If you get hold of the software you can reset any panel.
Im not a fan of it and once we have all of our estate on udl we will be disabling it.
How does the UDL software authenticate with the panels?
Well depends. If using modems then we use dial back and they call the office, either from a remote request or the customer pressing the relevant buttons. On the higher security stuff we use webways and the data is sent over an ssh tunnel.
Just for clarity Aritech ATS does use seed codes, Aritech CD does not.
wow, useless point scored there for the ats
I thought it a bit strange having such a big number. No idea why it is so.
