help
Guest b21playa
Guest b21playa
this one is for a mate of mine
just moved into house and te longe has two sensors
as sonas the sensor picks you up, the alarm goes off, not giving the entry delay
the zones are set to entry/exit and to 15seconds but still goes off.
the dor contact in the same room is set the same and that works
any idea what could be the fault and how it could be sorted
21708[/snapback]
need more info about room description
Guest b21playa
is a veitas r8 panel and using reflex pir's
room is 30ft x 12ft
front door is left hand corner with sensor above it pointing to centre of lounge. stairs in middle of room, so both sensors point to bottom of stairs.
will try and draw up a pic
Guest b21playa
are you sure all 3 zones are prog'd as entry/exit?
are you sure the front door contact is working?
21732[/snapback]
yes all are entry/exit
door contact is working, gives delay beep when door is opened, but the pir as soon as it picks a person up sounds the alarm
Perhaps the zones are wired incorrectly, like the tamper wired through the zone, or possibly they just arent correct with the zone spec (like zone 3 is actually on zone 5).
try programming the pir's as inhibited entry, although if you're sure about the programming and you're sure the detectors are wired to the zones you think they are, it shouldn't need to be that way.
If you don't know......ask.
