May 2, 201214 yr comment_283741 Hello! The alarm that we have inherited comes up with a +BAT MIS 0001 error code, which won't let us set the alarm. All worked fine for the last 3 years, I've recently replaced the batteries on each of the 4 wireless points after one of them had died. The info I've managed to get on this is as follows: --- CPO38 Honeywell Grade 3 Class II -- Galaxy 2-12 Version 1.44 -- ADT ED8 - 7300 PC+ABSFR Hope someone could tell me what the error code means (tried googling without luck)... I've seen some posts refer to the 12V battery, which I assume is the block on the wall opposite the keypad, could it be that it is on its way? Many Thanks! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 2, 201214 yr comment_283769 Main Control Panel Battery is probably faulty. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-283769 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 3, 201214 yr Author comment_283897 Thanks, will replace and see... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-283897 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 19, 201214 yr comment_285145 Hello - my alarm started showing the same error message. Can you please let me know what battery I need for this, and whether it's a simple job (or requires a technican to perform). I'm no longer monitored by ADT, and have a reasonable level of DIY/electrical skill! thanks! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-285145 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 19, 201214 yr comment_285147 If youve got the engineer code, then your in luck. If not - best to call someone in. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-285147 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 16, 201214 yr comment_290371 Its the main 7amp our battery i had this today i fitted a g2 20 and i ad and old batt in the van even thou it showed 13volts the amps where none exsistant i think the pannel must monitor the amps hense te error code Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-290371 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20205 yr comment_505603 Wonder if any one has any other suggestions, as I’ve replaced the main 12v battery in the control panel with a brand new one today and the error message will not clear down on exiting engineering mode Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-505603 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20205 yr comment_505604 Have you checked the voltage and charging rate with a meter during replacement? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-505604 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20205 yr comment_505620 Voltage with my meter indicated 12.78 volts and 385ma Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-505620 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20205 yr comment_505625 Voltage with my meter indicated 12.78 volts and 385ma, really strange went to set the alarm this evening - stuck in engineer mode due to error message of +batt missing 0001 has cleared by itself. So took alarm out of Engineer mode and it reset with no tamper errors or batt errors and reported 6 modules before and after and all ok. So don’t know what has happened between this morning and this evening but it seems ok. So let’s hope all is well. And big thanks for the swift reply earlier Edited October 23, 20205 yr by SteveO99 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32907-bat-mis-0001-error-on-galaxy-alarm/#findComment-505625 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
