Dualcom Gprs Grade 3 Dual Path Failure Reporting Times Test
Following on again from the LPS 1277 topic and after the dual path fail test on a redcare GSM this afternoon I did exactly the same on a Grade 3 Dualcom GPRS.
Powered down at 15:20 9/3/12 as shown in this video.
Last signal currently shown is the tamper from when i put the galaxy into engineers to open the panel. ie no GPRS fail or PSTN single path failures. Much less a confirmed comm fail (ie both paths down). System not put on test (as it wouldnt be in the wild if it was attacked. Exactly the same procedure as the redcare test. Unit is still powered down, im hoping that something will show up at some point.......
Last Checked at ARC @ 19:12 9/3/12
  • Replies 25
  • Views 14.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
I need to test another, but fortunatly i only have a handful of the non paknet based dualcoms. I would prefer to test a grade 4 one, but im fairly sure we dont have one. We used red gsm when G4 was needed.
I'm quite suprised to be fair over 4 hours now and not even a single path fail has been reported. Where is that document that says 3 mins lol
Ill do a redcare Secure 3 and a webway next week.
I checked that, it isnt on log only Plus im checking the log, so if it was on log only it would still be there.
Had a recent issue with 3 of our old plus units going into 72 hour polling failure. was told by csl to go to site and restart the units. No help. Turned out to be a fault at dualcoms end. Currently in a state of high confidence in these....
GPRS G3 should report simmultaneous path failure in 1hr, G4 version 3 mins
If yours did not I assume when comissioned polling was not enabled ?
maybe but how many will i have and if it isnt polling doesnt it report such.
Also i thought they set them to auto logon to the polling server as it was a problem that people didnt.
How do you know if it is or isnt polling?
I would prefer if someone else can test one of theirs to see if i have the only unit that doesnt work (well it isnt the unit as that is dead)
Ill need to test the red secures as i wonder if that is the same.
Just had a call from the ARC
Just been passed a Dual Path Failure from this. Just over 5 hours. So the document that talks about priority polling is not 100%.
I thought id get a single path failure quicker than this.
It seems to meet grade 3 and we must note this is a grade 3 unit. So its meeting the reg, but not the supplied by the manufacturer documentation.
Im assuming the redcare secure 3 will be the same on this attack type.
Id still be interested on anyone with a G4 unit verifying the 3 minute stat.
Ill update you all on the secure and ww1 tests
