Use Staples?
Yep agree. but unless you get the pressure spot on it crushes the cable. staple guns only have 2 settings, and there is no way of judging the hardness of the particular spot you are driving one into, so even if they had multiple settings, still no good for a coax. when i say crushes, its only a minor change of the shape of the cable that is needed to affect it, so staple guns are a no-no in the coaxial world :(
I've seen coax guns used, its got a much larger than staple than used in the rapid 28.
36?, don't have one but would be very handy for running mains flex under carpet !
if your gunning coax I assume you'd go insulted staples?
I would if I used one. Someone makes a staple with a "small plastic bridge" for want of a better description, so it only goes as deep as the leg. Hence it wont crush the cable. Think Ive even seen it advertised for Sparkies?
but for coax? a no-no imo.
I think it would depend on the quality of the cable, and insulating material.
Never seen any problems on site with un-insulated ones.
There 14mm long so hardly push on the cable at all.
Insulated Staples. Used one for Mains/Shotgun Cable very handy, staples can work out expensive tho.
There's a new type called UTAC which is a solid plastic staple, no metal at all.
UTAC staples are ideal for fixing to wood, fibre-board, all types of wood boards, plasterboard and even solid insulation blocks such as thermalite
arrow, still think no more than 50 volts ?
Only insulated/non metal staples if voltage higher than ELV.
I would be lost without my staplers, used correctly they make cabling look tidy.
