faugaballa Posted June 22, 2011 Share Posted June 22, 2011 Hi All, Wonder if anyone can suggest simple way of causing a buzzer to sound in the house when anyone goes between the piers to roadway. I'm having electric gates installed so there's mains power down there (about 60m from house) I've also got a 10-pair cable (exterior phone PJ filled, 0.5mm sq.) laid from gate control box to house so should be 5 or 6 pairs spare. I'm sure someone's hacked this one before. Many thanks Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 22, 2011 Share Posted June 22, 2011 Wonder if anyone can suggest simple way of causing a buzzer to sound in the house when anyone goes between the piers to roadway. I'm having electric gates installed so there's mains power down there (about 60m from house) I've also got a 10-pair cable (exterior phone PJ filled, 0.5mm sq.) laid from gate control box to house so should be 5 or 6 pairs spare. I'm sure someone's hacked this one before. A sensor (beam) wired to your alarm system on chime? Link to comment Share on other sites More sharing options...
9651 Posted June 22, 2011 Share Posted June 22, 2011 ....or if you dont have an alarm, some active beams connected to a timer relay via a buzzer to activate for 5 seconds or so? Do loads of this. Simplest way would be to connect to an existing alarm in the house though Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 23, 2011 Share Posted June 23, 2011 ....or if you dont have an alarm, some active beams connected to a timer relay via a buzzer to activate for 5 seconds or so? Do loads of this. Simplest way would be to connect to an existing alarm in the house though Good call I have done this too, but I know the OP has a Premier 24 (from another post) Link to comment Share on other sites More sharing options...
faugaballa Posted June 24, 2011 Author Share Posted June 24, 2011 OK sixwheelbeast (!) - Seems like a good idea since, as u kno, I've got the Prem24. Can u advise how to do this - would it be connecting a pair from NC relay (in IR beam cct at gate)to another Prem24 Zone? I'm presuming u can/could set this zone for chime only - that zone NEVER to cause an alarm? Might need a louder alerting sound than keypad 'chime' gives though - like could be working out back at the time on a windy day! Value ur comments Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 24, 2011 Share Posted June 24, 2011 Can u advise how to do this - would it be connecting a pair from NC relay (in IR beam cct at gate)to another Prem24 Zone? I'm presuming u can/could set this zone for chime only - that zone NEVER to cause an alarm? Might need a louder alerting sound than keypad 'chime' gives though - like could be working out back at the time on a windy day! You can use a zone on the alarm system, use two cores (one pair). Whatever you connect to on the gate/control MUST BE VOLTAGE FREE normally closed contacts, ideally off a clean relay. If you can't do that the simplest way is a new set of beams just for the chime. Wire that normally closed pair into the zone and program as normally closed. Program as Exit Terminator and setup for Chime. As for the volume fit an extention speaker to the alarm system you can also raise/lower the chime volume in Global Options. Link to comment Share on other sites More sharing options...
faugaballa Posted June 27, 2011 Author Share Posted June 27, 2011 Thanks for ur advice Link to comment Share on other sites More sharing options...
keeny Posted June 27, 2011 Share Posted June 27, 2011 hi, google driveway alert, they cost about £25 pound, wireless pir and remote chime, takes about 5 mins to install, fitted a few with no problems, . Link to comment Share on other sites More sharing options...
shedhappy Posted August 20, 2011 Share Posted August 20, 2011 Havn't got round to doing this - just been gathering the necessary bits like - A pair of Came Doc-e sensors to be fitted in gateway piers and an Elmdene 20 watt, 16 Ohm speaker near panel in Utility Room. Anyone know what's theTexecom 24's 'Spk' ouput characteristics, eg, would I need an audio amp module to drive the speaker to it's max rating and what should it's input impedance be for correct matching to panel? Thanks in anticipation Link to comment Share on other sites More sharing options...
james.wilson Posted August 20, 2011 Share Posted August 20, 2011 Standard is max 8 Ohm. Usually quote low power but i wouldnt use an external amp just use the speaker outputs as they are. If you need more speakers you can use something called a Hi-Lo sounder which drives a built in 16 Ohm speaker from a switch 12v supply. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
