Ats Levels And Failure Reporting Times
james.wilson
I think that's a fair comment James, and surprised you have not had any more comments on this.
Jim Carter
WebWayOne Ltd
www.webwayone.co.uk
i think the issue aaron is lack of understanding
ie dualpath must be better than single path? well in some cases yes but i wasnt fully aware of the facts and was led by the marketing sheets.
Ill be dooing some testing on units but im currently of the opinion that we (ie me) should be using G4 comms mainly, then when the risk is quite low, G3 but hardly ever use G2.
Currently we fit mainly G3 comms but we have been forced down this road recently by local cheap competition, but usually when you explain it to the client the want G4. If they dont care then they are usually quite happy with a digi.
Had a few people try and takeover some of our jobs latly and have tried to do it on price, ie rip out out red gsm and fir G2 dual path. When we explain to the client what that means they usually stick with red gsm.
And looking at the above
is an AT4 device doesnt have to report a PRIMARY path failure for 300mins. Assuming the backup path is still available??
that concerns me it really does
aaron i dont disagree, im sure you are fully aware how weak g2 is. I think the issue is many are not.
Ive always been anti very anti ip comms, but redcare gsm wont do extended formats, so im thinking i need to look at IP. Ideally what id want is a unit/service that can do IP/GPRS @ g4, but with a PSTN backup as well ie 3 paths. All sending SIA 3 allowing UDL over it, and with some sort of reporting system so i can see signal issues etc pro activly rather than reactivly.
  • 2 weeks later...
