A-I-S Posted May 1, 2009 Share Posted May 1, 2009 Hi Everyone bear with me i am new to this site, I have just put a system in with medusa detectors all is fine barr one detector it triggers the alarm but there are no sounders activated i have checked but it is not programmed to activate silently if anybody has come across this before i would be gratful to know how you sorted it Link to comment Share on other sites More sharing options...
james.wilson Posted May 1, 2009 Share Posted May 1, 2009 wont be anything to do with the sensor. Its either wired or programmed incorrectly. What panel and more info required etc securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
A-I-S Posted May 1, 2009 Author Share Posted May 1, 2009 Hi Everyone bear with me i am new to this site,I have just put a system in with medusa detectors all is fine barr one detector it triggers the alarm but there are no sounders activated i have checked but it is not programmed to activate silently if anybody has come across this before i would be gratful to know how you sorted it Hi have checked programming a dozen times it is an avanti xp panel and LCD rkp Link to comment Share on other sites More sharing options...
leesutton Posted May 1, 2009 Share Posted May 1, 2009 Have you tested the sounder with other zones? Â Lee Sutton E-Mail: leesutton@centurianfire.co.uk Website: www.centurianfire.co.uk Phone: 0845 094 9870 CENTURIAN FIRE & SECURITY (part of centurian group limited) Link to comment Share on other sites More sharing options...
A-I-S Posted May 2, 2009 Author Share Posted May 2, 2009 Hi have checked programming a dozen times it is an avanti xp panel and LCD rkp Yes all other zones work correctly the zone in question works on walk test but wont activate bell or internal sounder Link to comment Share on other sites More sharing options...
lawandorder Posted May 2, 2009 Share Posted May 2, 2009 Yes all other zones work correctly the zone in question works on walk test but wont activate bell or internal sounder As Redbull rightly says this is not a problem with the sensor. If the zone is showing in walk test when the sensor is triggered then there is a problem with the panel (either it is faulty or more likely the zone isn't programmed correctly). Wiring the sensor to another zone which does trigger the alarm will prove it for certain. I'm not familiar with this panel but possibly the zone is programmed to be "not used" or similar. Link to comment Share on other sites More sharing options...
A-I-S Posted May 2, 2009 Author Share Posted May 2, 2009 As Redbull rightly says this is not a problem with the sensor.If the zone is showing in walk test when the sensor is triggered then there is a problem with the panel (either it is faulty or more likely the zone isn't programmed correctly). Wiring the sensor to another zone which does trigger the alarm will prove it for certain. I'm not familiar with this panel but possibly the zone is programmed to be "not used" or similar. appreciate it will try in the morning Link to comment Share on other sites More sharing options...
dpaengineer Posted May 2, 2009 Share Posted May 2, 2009 Or.... The alarm and tamper loops are wired the wrong way in the pir and thus setting off on a tamper with you walkin front of it. Is it setting off all the time even when unset? Trade Member Link to comment Share on other sites More sharing options...
wilks121 Posted May 2, 2009 Share Posted May 2, 2009 Double knock comes to mind. Link to comment Share on other sites More sharing options...
Guest RJBsec Posted May 2, 2009 Share Posted May 2, 2009 Yes all other zones work correctly the zone in question works on walk test but wont activate bell or internal sounder If it works in walk test it is probably connected correctly. Is it in the programme that you are setting prior to making a full test, i.e. it's no good trying to test a detector on the landing if you've set it as bedtime part set! Hav you programmed it into the system as a security zone? Assuming that all other detectors cause an alarm activation when the system is set, it must be a programming issue whereby the detector is not in the programme you are setting, or it's not programmed as a zone that will cause an alarm activation. Link to comment Share on other sites More sharing options...
