Yoda Posted April 23, 2009 Share Posted April 23, 2009 Hi, im in the middle of trying to install the texecom premier 24 kit into my house, i got as far as buying the system, opening the box and cracking the seal on the installation manual. after reading the manual over 20+ times, im still no where near closer to knowing how to wire, where, what, how, when etc.... i have 8 sensors going into the system, 5 pir's and 3 door contacts, i wish for these to be indevidual zones, so a simple wire from the sensor to the zone board is what i need, however the manual dont say how to do that. plus i have 2 control panels, but i have worked out how to do them, just the wiring of the main board for the 8 sensors, the wiring for the actual pir's and the wiring for the door sensors, if you can help, i would be really happy! thanks in advance! Link to comment Share on other sites More sharing options...
Chorlton Posted April 23, 2009 Share Posted April 23, 2009 Texecom have (as far as I know) the best install manuals of all manfs. As John Wayne said : "A mans got to know his limitations" Bite the bullet & find a local company/engineer to help you IMO C. Link to comment Share on other sites More sharing options...
james.wilson Posted April 24, 2009 Share Posted April 24, 2009 pro gear is not designed for diy use. Id probably suggest if your that lost you find a local installer to help you out. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
BASS Posted April 24, 2009 Share Posted April 24, 2009 You really should have gone for something like Yale or Responses kit's. It sound to me you haven't a clue what your doing and have bitten off more than you can chew. My advice really is get someone in to do it or send it back. As the premier is a proffesional panel which we use for most of our install's. You may damage the panel if you don't know what your doing mate Link to comment Share on other sites More sharing options...
Yoda Posted April 24, 2009 Author Share Posted April 24, 2009 ok, ive worked out how to do the pir's myself, its just the wiring for the door sensors now, any ideas? Link to comment Share on other sites More sharing options...
james.wilson Posted April 24, 2009 Share Posted April 24, 2009 depends on what you have But if you have sorted the pirs it will be the same. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Yoda Posted April 24, 2009 Author Share Posted April 24, 2009 door sensors have 5 screws, 2 for the main sensor contact, and 3 others, i cant work out what they for and no instructions came with them Link to comment Share on other sites More sharing options...
aismoresecur Posted April 24, 2009 Share Posted April 24, 2009 door sensors have 5 screws, 2 for the main sensor contact, and 3 others, i cant work out what they for and no instructions came with them Use silver for alarm & brass for tamper Link to comment Share on other sites More sharing options...
Yoda Posted April 24, 2009 Author Share Posted April 24, 2009 any silver/brass? Link to comment Share on other sites More sharing options...
Phaeton Posted April 24, 2009 Share Posted April 24, 2009 Do you have a multimeter? If so you put your meter across the silver contacts there should not be a reading, bring the magnet close it should go to short, if they don't keep trying terminals till they do. Connect these to the same terminals as you did the PIR alarm contacts on the panel. For the anti-taper you don't say whether they are flush or surface & whether they have an extra set of contacts in them to detect them fastened to a surface in the case of flush. So it's difficult to advise you on that, not knowing the panel I don't know if each zone has it's own anti-tamper or a global anti-tamper, if it has it's own then anti-tamper will go to the device & then back, if it's global you need to daisy chain all the anti-tampers together. GET OUT CLAUSE:- I do not know this panel, I do not know if you can damage it, what I have given is general advice & may or may not be suitable for your instance, so you take the advice at your own peril. Alan... Link to comment Share on other sites More sharing options...
