Some Advice On Fire Alarm System For Domestic House
Thanks for the responses. I've checked with Building Control and they insist that we need a system that conforms to BS5839 part 1, even though it's a single family dwelling house!
If you don't mind me asking again, are the panels I listed really as bad as has been made out on here? It is a family house, and although we don't want to necessarily scrimp on something so important, we don't want to go OTT and get a system that may be overkill.
Panel from Screwfix
http://www.screwfix.com/prods/94522/Securi...-Panel-4-Zones#
Panel from TLC
http://www.tlc-direct.co.uk/Products/ESMAG4.html
I think the point they were making is that any system will have to be certified by the installer. If your planning this as a DIY id check to see if they will accept it without.
Equipment choice is a difficult one, I may like model x and hate model y, for differing reasons. The first you linked was a bottom end yet compliant panel.
But your installer will have choosen equipment that he supports and then all your research may be wasted.
If it's a fully domestic single family occupancy house then you don't need a fulll on fire alarm system - mains interlinked smoke detection with battery back up yes.
You do depending on the floor area of the house, last "big" house I commissioned had to have a full system....
I think it's more then 100m2 per floor if memory serves which it doesn't normally!
Is it in part 6???
Life is like a box of chocolates, some bugger always gets the nice ones!
My Amateur Radio Forum
Panel from Screwfix
Panel from TLC
Yes the panels will do the job but as said, the authority will want to see certification on the system, and may mention they would prefer a third party approved company.
Therefore you would be better off gettling a quote for the complete supply/install and commissioning of the job from a few companies.
If the place is nicely decorated and you don't want carpets up/ floor boards up and most likely cables showing, then you may consider a wireless system.... :)
BS pt.6 in the charts lists a house of three or more floors with >200m2 floor area have a full BS5839 alarm system.
Is it a statley home?
Guest Cerberus NI
Panel from Screwfix
Panel from TLC
Sounds like you may be encountering the old "I'm an official and I know best" type of department.
Part one does not relate directly to domestic dwellings but can be used as a reference to part 6 of BS5839 (2004) but here's a run down -
Grade D
