andymac Posted January 8, 2008 Share Posted January 8, 2008 Hi, My camera at the front door of my house gives a rubbish image. It is a cheap IR thing which i used at my old house with no problems. Now the image is just like a whitewash (see attached) Any ideas? (there is a garage door immediately to the right of the image and a car bonnet immediately to the left) could it be the reflection from the ir's?) Thanks Andy Link to comment Share on other sites More sharing options...
camerabloke Posted January 8, 2008 Share Posted January 8, 2008 lokks like to much light to be honest Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
andymac Posted January 8, 2008 Author Share Posted January 8, 2008 lokks like to much light to be honest From the ir's? Link to comment Share on other sites More sharing options...
camerabloke Posted January 8, 2008 Share Posted January 8, 2008 from an external light source. ie sun. try putting a makeshift cover over it to try and block some of the light and if that works, you will have to move it away from the light Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
andymac Posted January 8, 2008 Author Share Posted January 8, 2008 from an external light source. ie sun.try putting a makeshift cover over it to try and block some of the light and if that works, you will have to move it away from the lightthere are no other light on other than the ir's (which i tried to black out to no avail) and an orange street light opposite.Ta,Andythere are no other light on other than the ir's (which i tried to black out to no avail) and an orange street light opposite.Ta,Andyand it's dark as well pic taken tonight at 9pm.Ta,Andy Link to comment Share on other sites More sharing options...
satsuma01 Posted January 8, 2008 Share Posted January 8, 2008 from an external light source. ie sun.try putting a makeshift cover over it to try and block some of the light and if that works, you will have to move it away from the lightlooks to me more than likely the ir is reflecting off the glass case at the front of the camera where the rubber ring around the lens has not met the glass and ir light is filtering in from either side, what type of camera is it. can you unscrew the front part of the camera to pull the rubber/foam lens ring further up towards the glass casing "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment Share on other sites More sharing options...
andymac Posted January 8, 2008 Author Share Posted January 8, 2008 there are no other light on other than the ir's (which i tried to black out to no avail) and an orange street light opposite.Ta,Andyand it's dark as well pic taken tonight at 9pm.Ta,Andy It's one of those cheap ones, made in china I think,not tried to take apart althoough i cant remember if there are many obvious screws. I'll have alook tomin thelight, but i think a newone may be the answer, a decent one!! Could you recommend one. Thanks a lot. Andy Link to comment Share on other sites More sharing options...
luggsey Posted January 8, 2008 Share Posted January 8, 2008 Looks like moisture in the camera to me. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted January 8, 2008 Share Posted January 8, 2008 Looks like moisture in the camera to me. Link to comment Share on other sites More sharing options...
alterEGO Posted January 8, 2008 Share Posted January 8, 2008 Looks like moisture in the camera to me. it is, IMO. Link to comment Share on other sites More sharing options...
