Everything posted by J&D Security
Galexy G2 alarm with ir window vibration sensors
Did you check the back tamper was closed, if he fitted the back plate upside down then the back tamper would never work unless the sensor was also fitted upside down.
Adt codes
You've asked for two things which are against the forums rules. No defaulting info, or codes
- Hello all
Anyone worked in Australia?
I'd say they use a lot of Inner Range kit for intruder and access control, it's an Australian product, I've used it a couple of times in the UK.
- SD1 Dialler
Maglock Curiosity
http://www.electronics-tutorials.ws/electromagnetism/hall-effect.html
- New dude
hikvision dvr, ivms-4500 motion detection alarm problem
The static IP address for your device will be a local network address, just pick one in range and enter it in the dvr then forward the ports to this address. Your static IP from your ISP will be the address that the APP/Software uses to gain access from outside your local network.
You need to use your public IP address and set up port forwarding on you router, just google your router and port forwarding and make sure you use the public IP address not you local IP address.
You'll also need your public IP address not your Local IP address. Your public IP address should also be static which you can buy from you internet provider.
- Hello Everyone!
Small Bridal Shop Alarm and CCTV DIY Options?
I wouldn't say slating him just saying it's cheap and in their experience cheap means, the job gets thrown in. I say again if you're happy then go for it, no one can tell you whether to use him or not, unless they personally have come across his work before.
If you are happy with the quote and the company installing the systems, then go for it. People on here are just giving you their professional opinion that the quote is cheap, they're not trying to poach the work. Me personally I'd go for a wired alarm if it can be cabled and by the sound of it, it can. So to sum if you're happy with the quote, the equipment and the install company then give them the order to do the job. But make sure his price includes a warranty.
Ade Gen 4 Alarm Help
Either that or it's setup for engineer reset after tamper
Setting up dual beam sensors
How are you checking the alignment. The beams I've used before either had led indicators or you had to use a volt meter to measure an output and get the output into a certain range, different led's or voltages meant different alignment strength. There must be a method to check with this type of beam, perhaps they aren't aligned correctly.
As sixwheeledbeast said I doubt you'll find anyone on here that has used/knows the product. I would try them in close proximity to the panel/reciever to make sure it not a weak transmission signal. Set them up temporarily and test them.
- Fortress Access Control System
Texecom Premier Elite 48W - wireless PIR not triggering alarm
Stuart, As peter said the setting can be changed
When the bell sounds and you get a confirmed intruder from the wired PIR it that the only zone that has been activated or is it after another zone.
- a quick hello
Hi Everyone
Welcome to London where the roads belong to cyclists and pedestrians and motorists are a second thought. Only in london are pedestrians on walk for 3 minutes and cars on go for 3 seconds
inspire silver
Call the manufacturers tech support. They may be able to help get you back in, but may only talk to someone in the trade.
Mobile broadband
I have a paygo one on EE and it sits in a drawer and never gets used just use your phone as a wifi hotspot it's exactly the same thing. Most phone providers allow it in the UK but not abroad
- Hikvision Hdtvi Any Good?
