  1. Today
  2. Yesterday
  3. Last week
  5. Use a bucket, soap and sponge instead of buying a car washing machine!😉
  7. Thanks for the quick reply. Just been an expensive month - car, washing machine and alarm in the same week!!! Trying to keep costs down 🙂 What's your reasoning behind replacing them...reliability?
  11. Earlier
  13. Good job really
  19. I judged it by what you eat on a daily basis, I was gonna say lidl but that just might have been ever so slightly foreign for you Dave 😆
  20. probably all discounted & the bloke who fitted is long retired or dead ? I like to think on the bright side 🙂
  • Who's Online   1 Member, 0 Anonymous, 130 Guests (See full list)
    52,091
    Kevintog
    Kevintog
    446.6k
