  1. Today
  2. Use a bucket, soap and sponge instead of buying a car washing machine!
  3. You don't have to unless they give you trouble , although it's probably more of DIY product now with it's problems Just wire them double pole or correct resistors in place latter best way to go
  4. Thanks for the quick reply. Just been an expensive month - car, washing machine and alarm in the same week!!! Trying to keep costs down What's your reasoning behind replacing them...reliability?
  5. Should be compatible if you wired as double pole with commoned tampers. I'd probably replace them.
  6. Hi, My ancient Accenta8 alarm panel has given up and I plan to replace it with a Texecom Premier Elite 24. I have swapped all the original PIRs for Honeywell IS312 as I decorated each room. Are PIRs basically standard and compatible with most alarms or do I need to replace the PIRs if I install the Texecom panel? Thanks Chris
  7. Good morning, We are currently looking to recruit experienced CCTV, Access Control, Intruder engineer to carry out installations and servicing. Must be reliable and willing to learn. Thanks
  8. Yesterday
  9. Last week
  11. Good job really
  27. Morrisons is a bit posh for up here... Heron or Farmfoods maybe?
  • Who's Online   1 Member, 0 Anonymous, 157 Guests (See full list)
    52,054
    crispylees
    crispylees
    446.6k
