  1. Today
  2. Yesterday
  3. Last week
  12. Good job really
  19. probably all discounted & the bloke who fitted is long retired or dead ? I like to think on the bright side
  20. I'd assume the fire doors & shoplifters ? But could be anything ? Sainsbury's is my preferred super market. then maybe Tesco ? Morrison's is pretty much - unwashed scum of the earth which makes an Asda look posh, My local Waitrose has an lovely "drain" smell about it, go in your workwear & security follows you I have a nice Heron's & also Heron's on the council estates...these along with farmfoods are brilliant. Go in the store in suit & says please & thank to checkout person & they think you must be a mystery shopper or from snooping from head office !
  21. Earlier
  • Who's Online   0 Members, 0 Anonymous, 31 Guests (See full list)
    52,060
    BurtonSal
    BurtonSal
    446.6k
