  1. Past hour
  2. Yesterday
  3. If you get the same manufacturer as the panel you will have EOL OOTB. I don't really rate those cheap Honeywells, some nice quads will be much more reliable. Much better down the line to have end-of-line than double pole to diagnose faults.
  4. Use a bucket, soap and sponge instead of buying a car washing machine!
  5. You don't have to unless they give you trouble , although it's probably more of DIY product now with it's problems Just wire them double pole or correct resistors in place latter best way to go
  6. Thanks for the quick reply. Just been an expensive month - car, washing machine and alarm in the same week!!! Trying to keep costs down What's your reasoning behind replacing them...reliability?
  7. Should be compatible if you wired as double pole with commoned tampers. I'd probably replace them.
  8. Hi, My ancient Accenta8 alarm panel has given up and I plan to replace it with a Texecom Premier Elite 24. I have swapped all the original PIRs for Honeywell IS312 as I decorated each room. Are PIRs basically standard and compatible with most alarms or do I need to replace the PIRs if I install the Texecom panel? Thanks Chris
  9. Good morning, We are currently looking to recruit experienced CCTV, Access Control, Intruder engineer to carry out installations and servicing. Must be reliable and willing to learn. Thanks
  10. Last week
  12. Good job really
  19. probably all discounted & the bloke who fitted is long retired or dead ? I like to think on the bright side
  20. I'd assume the fire doors & shoplifters ? But could be anything ? Sainsbury's is my preferred super market. then maybe Tesco ? Morrison's is pretty much - unwashed scum of the earth which makes an Asda look posh, My local Waitrose has an lovely "drain" smell about it, go in your workwear & security follows you I have a nice Heron's & also Heron's on the council estates...these along with farmfoods are brilliant. Go in the store in suit & says please & thank to checkout person & they think you must be a mystery shopper or from snooping from head office !
  21. Does this not mean it reaches grade 3 requirements??? Although this is the sc105
  22. Is product available that is graded? If yes then you cant use, if no then it would yes Also there may not be a EN for that detector (id of thought it would fall under shock though)
  23. Oh I thought it was french lol
  26. I would have thought they have some other kind of certification as opposed to stating they are grade 2/3
  27. Earlier
