  1. Past hour
  2. Today
  3. Yesterday
  4. Last week
  5. If you get the same manufacturer as the panel you will have EOL OOTB. I don't really rate those cheap Honeywells, some nice quads will be much more reliable. Much better down the line to have end-of-line than double pole to diagnose faults.
  6. Use a bucket, soap and sponge instead of buying a car washing machine!
  7. You don't have to unless they give you trouble , although it's probably more of DIY product now with it's problems Just wire them double pole or correct resistors in place latter best way to go
  8. Thanks for the quick reply. Just been an expensive month - car, washing machine and alarm in the same week!!! Trying to keep costs down What's your reasoning behind replacing them...reliability?
  9. Should be compatible if you wired as double pole with commoned tampers. I'd probably replace them.
  10. Hi, My ancient Accenta8 alarm panel has given up and I plan to replace it with a Texecom Premier Elite 24. I have swapped all the original PIRs for Honeywell IS312 as I decorated each room. Are PIRs basically standard and compatible with most alarms or do I need to replace the PIRs if I install the Texecom panel? Thanks Chris
  11. Good morning, We are currently looking to recruit experienced CCTV, Access Control, Intruder engineer to carry out installations and servicing. Must be reliable and willing to learn. Thanks
  13. Good job really
  22. Earlier
  23. Does this not mean it reaches grade 3 requirements??? Although this is the sc105
  24. Is product available that is graded? If yes then you cant use, if no then it would yes Also there may not be a EN for that detector (id of thought it would fall under shock though)
  25. Oh I thought it was french lol
  26. They have some German VDS approvals but nothing which is UK specific.
  27. Chatgpt makes things up maybe Red intruder activation White pulsing deterrent light at night or when set Yellow indicator for fault What you think ? Chatblag?
  28. I would have thought they have some other kind of certification as opposed to stating they are grade 2/3
  29. Hi All, Bit of a compliance question here... We have been asked to fit Honeywell SC100 seismic sensors on a G3 system however the SC100's dont seem to bear any security grading. I know these are used industry wide and they are "the right" bits of kit for the job but how can they be fitted on a graded system without affecting the overall system grading?
  • Who's Online   3 Members, 0 Anonymous, 201 Guests (See full list)
    52,061
    jcww
    jcww
    446.6k
