Guard Access ?
Thank you Mr Happy...... I have this morning programmed zones 1 to 8 as normally closed and am now able to use the alarm........ Your help has been much appreciated, thank you. Regards. - Last week
elliotcardno joined the community
simonses joined the community
Ruth joined the community
al-yeti started following Risco RWT72i Door Magnet Draining battery’s and getting hot!
LewisLewLew3492 joined the community
Eric801 joined the community
9651 started following Shunt locks
1231afa joined the community
Xuper IT joined the community
claimcash2191 started following Hello!!!
Its a two year old thread I doubt that he will reply. In answer to your question. In most cases hard wired detectors are compatible with any brand of panel, you will most likely have to change end of line resistors along with the panel.
Who's Online 0 Members, 0 Anonymous, 79 Guests (See full list)
Total Topics446.4k
