Visonic powermaster 30 part settings help
james.wilson replied to naeem7861's topic in !!..DIY Installers..!!
You want omit on part set? -
Visonic powermax help needed please
Thought so -
Visonic kp-160 enrolling help please
What's the issue? -
Does anyone know how program the panel for part settings for night zones tobe active also I wanted to use my kp-160 keypad todo that to any help would be greatfull thanks I have my eng code
naeem7861 replied to naeem7861's topic in !!..DIY Installers..!!
Hi I got a visonic powermaster30 I need to enroll a visonic kp-160 wireless keypad can anyone help please
Hi thanks for getting back to me everything is working on the panel I got the eng code I need to enter settings for partsettings for night zones can anyone help please -
Hi thanks for getting back to me everything works but I need to program the panel for part settings for night zones to arm only -
Hi thanks for getting back to me so you can only use the this panel with the same frequency devices correct ??? - Last week
Hello everyone, I need your help! I'm installing a RISCO LightSys plus panel with the wireless module. The house is very large, so I had to use repeaters. However, after finishing the programming of the sensors, there is a download of the "Repeater.BIN" file between the panel and the repeater, and this download always fails, causing the detectors to never stay on the repeater. Does anyone know how to solve this? Thank you.
Hello everyone, it's a pleasure to be here. I'm an engineer from Portugal
Yes it's different.
I am replacing an existing old bell box with a Reson 8 bell box 8EP420. My alarm panel is a Optima G4. They are connected via a 4 core cable. The existing panel wiring is as follows: Panel Bell box Strobe+ (no connection) A link between T and A Strobe- (yellow) A (blk) SCB D (red)Bell+ B (blue) Bell- The Reson8 install guide only shows a 5 wire system: Panel Bell box Strobe- Stb- B (Bell-) Trig- A- Hold off - D (Bell+) Hold off + T- Rtn - I cant work out how I should wire the Reson8 from this. Any Alarm installers able to offer advice? Quote Reply to BernieA Report •••
I believe different frequency prevents the use of normal visonic devices
You can but we don't give advice on how to defeat systems which a default does. I'm sure you are genuine but others are not. Not sure if aft badged gear has different firmware stopping it's use as generic visonic maybe someone else here with experience knows? -
Hi James also can I factory reset the codes to default would be greatfull -
It's a powermaster 30 can it work with the visonic go app -
Hi sorry yes it's a powermaster -
powermax as in the really old one or powermaster?
Who's Online 0 Members, 0 Anonymous, 119 Guests (See full list)
33.2k
Total Topics443.8k
