  1. Last week
  9. Close.... I got high Vis on
  10. Good job really
  11. Never staying on topic... I think this one may we wired a little shirt ?
  12. My local supermarket now is Tesco Express and Waitrose. I must say there is a noticeable difference between both, with price and quality. Its rare I spend less than £20.00 when I go in Waitrose for a few bits, and its rare I spend more than £10.00 in Tesco. I never buy the same stuff in either though.
  13. Lidl bakery useful. Aldi don't like at all.
  14. fair comment, can any one tell the difference betweena lidl & aldi ?
  15. Im not over keen on Sainsbury's their meal deals are deliberately confusing and nobody really likes Jamie Oliver with his waste the difference
  16. I judged it by what you eat on a daily basis, I was gonna say lidl but that just might have been ever so slightly foreign for you Dave
  17. Earlier
  • Who's Online   1 Member, 0 Anonymous, 196 Guests (See full list)
    52,072
    Claudeson
    Claudeson
    446.6k
