  1. Yesterday
  9. Last week
  11. Good job really
  21. Earlier
  22. Is product available that is graded? If yes then you cant use, if no then it would yes Also there may not be a EN for that detector (id of thought it would fall under shock though)
  23. Oh I thought it was french lol
  26. I would have thought they have some other kind of certification as opposed to stating they are grade 2/3
  27. Hi All, Bit of a compliance question here... We have been asked to fit Honeywell SC100 seismic sensors on a G3 system however the SC100's dont seem to bear any security grading. I know these are used industry wide and they are "the right" bits of kit for the job but how can they be fitted on a graded system without affecting the overall system grading?
  • Who's Online   1 Member, 0 Anonymous, 82 Guests (See full list)
    52,057
    benamindark4936
    benamindark4936
    446.6k
