  1. Last week
  9. Close.... I got high Vis on
  10. Good job really
  11. Never staying on topic... I think this one may we wired a little shirt ?
  12. My local supermarket now is Tesco Express and Waitrose. I must say there is a noticeable difference between both, with price and quality. Its rare I spend less than £20.00 when I go in Waitrose for a few bits, and its rare I spend more than £10.00 in Tesco. I never buy the same stuff in either though.
  13. Lidl bakery useful. Aldi don't like at all.
  14. fair comment, can any one tell the difference betweena lidl & aldi ?
  15. Im not over keen on Sainsbury's their meal deals are deliberately confusing and nobody really likes Jamie Oliver with his waste the difference
  16. I judged it by what you eat on a daily basis, I was gonna say lidl but that just might have been ever so slightly foreign for you Dave
  17. probably all discounted & the bloke who fitted is long retired or dead ? I like to think on the bright side
  18. I'd assume the fire doors & shoplifters ? But could be anything ? Sainsbury's is my preferred super market. then maybe Tesco ? Morrison's is pretty much - unwashed scum of the earth which makes an Asda look posh, My local Waitrose has an lovely "drain" smell about it, go in your workwear & security follows you I have a nice Heron's & also Heron's on the council estates...these along with farmfoods are brilliant. Go in the store in suit & says please & thank to checkout person & they think you must be a mystery shopper or from snooping from head office !
  19. Earlier
  • Who's Online   1 Member, 0 Anonymous, 100 Guests (See full list)
    52,068
    zangeltianov7385
    zangeltianov7385
    446.6k
