  1. Last week
  9. Close.... I got high Vis on
  10. Good job really
  11. Never staying on topic... I think this one may we wired a little shirt ?
  12. My local supermarket now is Tesco Express and Waitrose. I must say there is a noticeable difference between both, with price and quality. Its rare I spend less than £20.00 when I go in Waitrose for a few bits, and its rare I spend more than £10.00 in Tesco. I never buy the same stuff in either though.
  13. Lidl bakery useful. Aldi don't like at all.
  14. Earlier
  • Who's Online   1 Member, 0 Anonymous, 201 Guests (See full list)
    52,076
    BlueLighting73
    BlueLighting73
    446.6k
