  1. Yesterday
  9. Last week
  11. Good job really
  26. Earlier
  27. Hi All, Bit of a compliance question here... We have been asked to fit Honeywell SC100 seismic sensors on a G3 system however the SC100's dont seem to bear any security grading. I know these are used industry wide and they are "the right" bits of kit for the job but how can they be fitted on a graded system without affecting the overall system grading?
  • Who's Online   1 Member, 0 Anonymous, 117 Guests (See full list)
    52,055
    Andy Cooke
    Andy Cooke
    446.6k
