help me please
Guest gorin
Guest gorin
Presuming you mean your putting the code in the RKP - sounds like a blown fuse on the rkp line - if the leds dont light on the keypad then its that.
54083[/snapback]
the power light comes on the keypad and when i punch the code in each number still chimes i have checked the fuse and its ok
when u powered the system down did you do mains and battery or just mains?
The default user code on one of those is 0123 by the way.
54089[/snapback]
oops just read the eng manual and found that out lol.
sorry, my bad.
Regards
Bellman
Is it the normal siren sound or is it pulsing on and off?
54093[/snapback]
I like the way your thinking - If it was a 24hr fire zone it would go off straight away -although the cust code should still silence it though :(
54096[/snapback]
Sometimes lock you out on 24h fire zone don
Its poss, but the user code or default code should still silence the alarm even if it were in a tamper condition or fire alarm 24hr zone - unless the bells in tamper with a duff sab - so when he juices the panel its feeding the siren whilst in tamper condition or something???
On some G3 the first ones if a fire zone was active then the sounders would not stop until the zone had cleared
54107[/snapback]
Really, so as robert suggested by his post it could still be due to the disconnect of the S/A - in that case he just needs to link out the zone in the panel that he took the S/A's wires out of.
