Connect External Sounder
Hello.
Apologies for the long message.
Obviously technology changes and as I’ve been retired for a number of years it’s has changed.
The Home Alarm system I fitted 20 plus years ago has finally given up so I have purchased an Eaton Scantronic PAN-10W-K
Included with the Unit were QR codes to download User and Installer Manuals.
While I was able to download the User Manual I was unable to download the installation Manual as I had to register my details and as I was not part of a company I was unable to do so.
So this means I have a problem with some connections as the Main PCB connections are not obvious.
The connections for the PIRs seem to be obvious with two zones sharing a common connector and a dedicated connector for each PIR.
So I will wire the PIRs ( Without EOL resistors ) , no problem but I will not bother with the Tamper Wires unless someone thinks it’s a good Idea that I should. If I don’t connect Tamper there must be a wired link I should do so where / how. If I do connect the Tamper wires where do I connect on the Main PCB ( See Below ).
I realise that he Tamper for the Keypad is done digitally.
My problem / Confusion is connecting the External Sounder.
The old Alarm showed connections as,
-R    Sounder Tamper Return ( Negative )
- Sounder Hold Off / Supply ( negative )
+ Sounder Hold Off / Strobe ( Positive )
S  Sounder Switched Negative Trigger
ST  Sounder Switched Negative Trigger
There are Ten connections on the Eaton Scantronic PAN-10W-K.
0v , 0v  , 12v Aux , 12v Aux , OP1 , OP2 , OP3 , TR , LB+ , LB-
I suspect that one the 0v and 12v Aux can be used for the voltage to the PIRs but where / how do I connect he Sounder ?.
While I have not connected / powered up the unit when I do I have to hold both the A button and Tick button at the same time.
One of the options is 2 wire FSL  but this also shows 2k2 / 4k7 which is for EOL resistors. As I won’t be using EOL resistors is this a problem or is there another setting ?.
Many thanks in advance for help, advice and suggestions.
Don.
Recently Browsing 1
