Fire alarm Sub contracting Bafe
Evening All
I have decided to go subbying after 15 years within the industry, and looking for some guidance in regards to installing fire alarms. If you are sub contracting to a company that are Bafe registered, does the sub contractor have to be Bafe registered in order to install?
16 minutes ago, SubbyFS said:
Evening All
You don't need to be registered anywhere for anything if the company who is hiring you is registered, your representing them not yourself
But would be handy if you have skilz lol
Thanks for the reply.
I'm guessing I’m just misinterpreting the attached? Aslong as the company who’s contracted to install the job is Bafe registered that covers it?
BAFE-SP203-1-Version-8-0-Guidance-Note-Sub-Contractors.pdf
your document appears to have a requirement for the installation work to be undertaken by an electrical contractor with nic eic or similar ?
Electrical part only right.....
