Hikvision Doorbell - Pulling stream into Non Hik NVR
On 23/10/2024 at 21:43, bm99 said:
Hi all, i have a hikvision KV6113 - WPE1 C doorbell
Im upgrading my DVR which is also going to have some IP cams added and want to pull the stream of the doorbell in.
Am i limited with which recorder can i use or can i bring the stream into any DVR which also has Ip cams added?
You can use any DVR/NVR that supports IP camera streaming.
You will likely need to input the doorbell's IP address and other details like the streaming credentials (username, password) in the NVR settings.
Consider Using Hik-Connect App.
Once everything is set up, you should be able to view both your IP cameras and the doorbell stream seamlessly.
If you need specific guidance on configuration, feel free to ask!
  • 1 year later...
  • Replies 21
  • Views 6k
Because the doorbell does not expose ONVIF, I would choose an NVR that allows a generic RTSP camera to be added manually, rather than relying on auto-discovery. Test the main and substream credentials in VLC first, then add the working stream on a spare IP channel. The call and ring features can stay in the doorbell app.
