Eaton KEY-KPZ01 rapid red flashing
I programmed an i-onG2SM, in my office. PIRs door contacts, KEY-KPZ01 and network access. Everything worked OK.
II then connected it to the actual system, replacing an old Ademco Galaxy. The only thing I didn't connect was the  bell box. I also only had the keypad on a short wire, local to the box, while I tested everything else for a few days. This also worked.
I have now connected the bell/ strobe and used the old wires to replace the Galaxy keypad with my KEY-KPZ01.
For some reason the keypad will only constantly display the Eaton logo and an old date, and the navigation button rapidly flashes red.
Pressing any key just causes a beep but does nothing else.
The system still works through the Secureconnect app. but I can't do anything with the keypad.
Any ideas would be much appreciated.
Thanks in advance
Thanks in advance
Cable fault, I assume it worked on the bench with short cable or check there's no strand shorting out where you connect wires, if spare cores try them instead to keypad
Agreed sounds like a keypad comms issue. However I'd thought you would get faults reported / logged
Maybe then keypad issue
Thanks in advance
Althought have you managed to delete the keypad? And need to add it back as a device
Does the app allow a virtual keypad? Go through it and see if it sees keypad or not as a wired device
