BlueDay Posted May 22, 2023 Share Posted May 22, 2023 Hi all Currently in a dispute with my employer about traffic barriers/sliding gates. We've always subbed faults and services out to another company, but now my employer has decided to save money by getting us to do it with no training provided. A lot of engineers on the company (including myself) have no experience working with barriers/gates and I don't feel comfortable putting my name to something to say it is safe when I've not received any instruction or guidance. If its just a case of testing safety loops, then fair enough I can do that. But surely there is more to it than that? The company that subbed to us definitely used to do more than that. Anyone know any regulations or anything regarding training and competence I can refer them to? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted May 22, 2023 Share Posted May 22, 2023 Most gate and barrier suppliers will point you in the right direction for training. LinkCare I think even run their own training courses. Not really saving money by sending people that dont know what they are doing. Id rather put round pegs in round holes. But most gate and barrier companies seem to be too busy with their own stuff to want to sub for anyone else nowadays. Our guys are okay on service and maint and can install, but we regularly sub the install work out its cheaper to get someone that does it everyday to do it in the long run. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted May 22, 2023 Share Posted May 22, 2023 Engineer would be liable for any fault leading to injury or death just like with fire, so I would refuse to do any of it without correct training. Plenty of jail sentences and fines in the news... Also insurance for the company is higher if you add gates to your services, either specialise and train correctly for it or sub IMO. Gate-safe is one path of training, which is a ECS discipline. https://www.hse.gov.uk/work-equipment-machinery/powered-gates/safety.htm https://www.hse.gov.uk/safetybulletins/poweredgates.htm https://gate-safe.org/ As above suppliers will have their own scheme but it's going to be based on their supplied kit. 1 Quote Link to comment Share on other sites More sharing options...
BlueDay Posted May 26, 2023 Author Share Posted May 26, 2023 Thanks guys. Still discussing with my employer Is there also any specialist equipment require in service gates/barriers? One of the sites mentioned force measuring equipment? Also how long does it realistically take to service these properly? So I can pass the information back Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 26, 2023 Share Posted May 26, 2023 3 hours ago, BlueDay said: Thanks guys. Still discussing with my employer Is there also any specialist equipment require in service gates/barriers? One of the sites mentioned force measuring equipment? Also how long does it realistically take to service these properly? So I can pass the information back Sounds like your going to need lots of liability insurance Quote Link to comment Share on other sites More sharing options...
PeterJames Posted May 26, 2023 Share Posted May 26, 2023 4 hours ago, BlueDay said: Thanks guys. Still discussing with my employer Is there also any specialist equipment require in service gates/barriers? One of the sites mentioned force measuring equipment? Also how long does it realistically take to service these properly? So I can pass the information back Your employer should have barriers and gates down on his efficacy insurance otherwise you could be in trouble if you do make a mistake. Force measuring equipment is fairly important especially if the gate your servicing is on a gradient. though as a rule you should be testing force regardless. Servicing depends on the gate/barrier type of motor etc how many ground loops etc etc. You also need to take into account how many times you can operate the gate in short succession testing is all very well but on the same token you dont want to burn the motor out so even small gates can take ten minutes. Quote Link to comment Share on other sites More sharing options...
