UKAlarmGuy Posted March 26, 2023 Share Posted March 26, 2023 (edited) Does anyone know if the Optima XM6 panels were known for the battery circuit going kaput, we have one, battery dead, even if we changed the battery, the battery circuit is kaput so a new battery won't keep the panel powered during a power cut, panel works by the way. Sounds stupid I know, but it is a genuine question, as our one is the only one AFAIK that has the battery circuit issue Edited March 26, 2023 by UKAlarmGuy Extra info Alarm enthusiast and furry Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45549-question/ Share on other sites More sharing options...
sixwheeledbeast Posted March 26, 2023 Share Posted March 26, 2023 Ah a question... Yes I'd say most old ADE stuff I see is tired and has either no or very low charging rate. Every battery replacement should come with checking the charging rate and off mains change over, it's pointless and wasteful throwing a new battery in for it to drain out. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45549-question/#findComment-518328 Share on other sites More sharing options...
UKAlarmGuy Posted March 26, 2023 Author Share Posted March 26, 2023 Just now, sixwheeledbeast said: Ah a question... Yes I'd say most old ADE stuff I see is tired and has either no or very low charging rate. Every battery replacement should come with checking the charging rate and off mains change over, it's pointless and wasteful throwing a new battery in for it to drain out. Makes sense, we don't really use it unless we've had a power cut otherwise it rings for 20 minutes on the external sounder and the panel sounder Alarm enthusiast and furry Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45549-question/#findComment-518329 Share on other sites More sharing options...
