(Chubb) Guardall Balmoral CA600 Line Fault.
Hi. I am searching for someone who may know how to diagnose a ‘line fault’ on an old
Balmoral panel. Unfortunately, I haven’t been able to find an engineer manual (or a user manual for that matter) so I was wondering if anyone knows about these panels. I suspect it will be to do with comms or data? I have gone through the programming/engineer options  but to no avail. I am aware that engineer manuals cannot be published publicly on here. BTW I collect alarms hence why I have such an old panel.
Thanks.
I'd of thought you could just pull up or down the lf input?
stick 12v into line fault, if its starts smoking, remove
or stick 0v into line fault, if starts smoking remove
