rpatel2 Posted January 11, 2023 Share Posted January 11, 2023 Hi all I've just been trying to demo out my predominately wireless ION-40H system. The only part which is wired, is the sounder. Most of the connections have a direct label in the control panel, however, i'm getting confused over the ENG input which appears on my siren. The manual says, output of type "installer on Site". However, i cannot locate a relevant connection on my control panel I've attached manual screenshots of both the bell inputs and my control panel diagram. Any advice is much appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 11, 2023 Share Posted January 11, 2023 There won't be a dedicated one, it means an output needs programming to that type. Should work fine without it. Quote Link to comment Share on other sites More sharing options...
rpatel2 Posted January 12, 2023 Author Share Posted January 12, 2023 @sixwheeledbeast thank you. I will install without it. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 12, 2023 Share Posted January 12, 2023 Logic would say if you have enough wires, stick a wire in everything deal with it at the panel end later... From a DIY POV anyway... Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 12, 2023 Share Posted January 12, 2023 8 hours ago, rpatel2 said: @sixwheeledbeast thank you. I will install without it. As swb says stick a wire on it , and if you ever want to disable tampers some bells require to be connected temporary to 0v or something like that , then you can open bell without the siren going off or something like Quote Link to comment Share on other sites More sharing options...
