Texecom Expander Help
Hi
Just installed a Texecom premier elite 24 metal case with an expander at a distance from the panel.
Just need to know if I can add 2 bell boxes to the expander and what connections to use on the expander to add them.
Also Just to let you know there are no other bell boxes attached to the panel, but attaching them to the expander if possible would make cabling a lot easier due to the distance.
Thanks for any help.
48 minutes ago, Tas said:
Hi
Powered expander ?
2 bells some distance from the controls connected to this-
Texecom Premier Elite 8XP Remote Zone Expander CCB-0001
no,
Lenz Security on Twitter: "A day in the life of Alarm Installation.  Completely wired (CQR Cable) and Texecom Alarm, with 2 expanders and over  20 zones. @TexecomLtd @_CQR #texecom #alarm #secure #hardWired #
the small item within or with a local psu, yes
what sounder ?
If you want to have SAB's then you need a PSU200XP. If in the quieter SCB mode then possibly but you will have to check your current isn't overloading the panel.
You'll need to program the outputs and input correctly or it will FTO correctly.
Thanks for your help and advice noted.
I think I am going to have to rethink the setup.
I did mention this in your Veritas thread, panels generally only have enough capacity to supply themselves, a keypad, sensors and one SAB.
The maximum current that can be supplied by it's power supply is not always the limiting factor, you do calculations based on standby battery capacity.
If you have 2 bells there is a low current mode on most new texecom SABs to let you get away with this
