Orisec Engineer code stopped working
23 hours ago, Imnotshankled said:
Unfortunately you can't   if you have a tag to let you in engineer I can give you a COTD code  the only option is to default and start fresh
? - switch off the mains and disconnecting the battery? And that will restore factory default codes and I’ll start again
  • Replies 28
  • Views 9.5k
2 hours ago, MrHappy said:
Eng code is lockable ?
Yes however you would get a different response
All sorted now with engineer code thanks al
Now got thr new wireless device with new battery giving me a “low battery” notification. Even though showing 2.8v on the panel??…anyone had this
Are you using eBay sorced stuff or direct from orisec
The one that's giving me problems was direct from orisec...but i have bought a couple of other orisec boxed ones from ebay - are you going to tell me they are rejects from Orisec
If you ordered it from contact orisec and they will send you a shipping label and a replacement for free   and tbh if you are using the in panel receiver don't expect more than 5m range without a external antenna
Edited by Imnotshankled
Its been working for a year no problems.  I just moved it and put a new battery in and now its giving me a warning...i might just change the battery and see if it solves
You didn't do that already?
? yep, put a brand new battery in when i moved it - maybe it doesn't like this battery and another new one would help...#clutching
Do orisec know you undo their whole trade and direct only? I don't think they class themselves as amazon.
