Honeywell DT-7235T SESNSOR
Hello all,
i'm new in this field and im using a sensor Honeywell DT-7235T and i want to connect alarm with it,
the sensor is working when i plugged but when it try to connect the alarm with it doesn't trigger !
anyone can help !
they are 4 pins 2 for power and 2 for alarm and there is also the tamper ?
should i connect the tamper to trigger the alarm ?
thanks for help.
56 minutes ago, aouelali said:
Hello all,
anyone can help !
thanks for help.
What alarm panel are you connecting it to?
Power goes to power
Alarm goes to alarm
Tamper goes to tamper
However you may need eol , which can be explained if you give more detail of alarm panel
as above what you wiring it into?
