Honeywell Galaxy Dimension Grade 2/3
please create a topic for each issue
3 hours ago, GalaxyGuy said:
No, that's the MAX reader number printed on the black fob.  The number scanned by the keyprox is correct. You need to configure the users menu to link the MAX tag to the setting function if you want to use to set the system - you then need to hold the tag to the reader until the setting countdown shows on the display.
Nice one. This means it does work. I just expected it to be more instantaneous, when presenting the fob. Thank you.
The card held function is something I'd like to see from other manufacturers. Prevents false alarms by people who are not trained on using the system. If you can't set it, you can't set it off
for setting you have to wait , for unsetting its quicker , at least that's what i see, use to annoy customers on the galaxy
Yes.  Just need to sort all the error messages that apers when setting the system. In my case that 'Line Fail' was killing me. Just in case anyone else has it and not using the line then it's in 56.1.10.1.0
yes disable line fault monitoring. Its going to be more of an issue with BT killing pstn lines. Im sure we will see more of it on here soon. Who could of predicted it...
Are those sentences related to each other? Tell that story, old man.
Bt are changing from pstn so I'm expecting lots of issues with older communicators that use pstn
